Collection of Data Help
  • Lito
    • Nov 2020
    I have a collection of data that I can extract / export as CSV or using Zabbix API- However, I need help understanding what is the best way to group those data and which type of items they should be. See this image as an example of the data that I have and the Dashboard/graph that I need to create:
Name:	Data Examples.png
    The main problem is that I could have 1000 of data (First Column)- I don't think is feasible to create an item for each of them or the server will overload (Is there another way?). User, Type, and Location are only a few so I could create them as separate items.
    Any Advice?
    Thank you
  • Singularity
    • Aug 2020
    • 81
    To dynamically create items from data, LLD ( Low Level Discovery ) is used in zabbix.
