Zabbix not send variables for script
  • fabiosoares
    • Jul 2015
    • 9
    I have two servers, one is Zabbix, and the other to use as sending Script's.
    Server one - Zabbix Server installed
    Server two - Raspberry (Debian installed with Huawei device connected to perform sending sms GSM). Apt gammu installed.
    I have e-mail script, working.
    I made an ssh connection without a password between the two, and created the following script at /etc/zabbix/alertscripts:
    #! / bin / bash
    ssh [email protected] "echo "$1" "$2" | gammu sendsms TEXT "$3"";
    Manually works.
    When I drop a VM tests, Zabbix alarm and send email and sms, email is received, the sms not.
    I performed the following test:
    #! / bin / bash
    ssh [email protected] "echo "$1" "$2" "$3" >> test.txt"
    Manually works.
    But does not receive zabbix variables
    What to do?
  • akbar415
    • May 2015
    • 119
    #! / bin / bash
    Manually works.
    #! / bin / bash
    Manually works.
    What to do?
    I think the problem is remote machine don't understand the local machine variable
    Try this
    # Use the ssh to set ARG1 and ARG2 on remote host and open a ssh connection
    ssh [email][email protected][/email] ARG1=$1 ARG2=$2'bash -s' <<'ENDSSH'
    #Here you can put all command you want
    gammu sendsms TEXT $ARG1 $ARG2
    # This end the remote command
    ENDSSH
    I hope this helps you
    • fabiosoares
      • Jul 2015
      • 9
      Try this
      ENDSSH
      I will try, I'm having some problems with Firewall, so resolve post saying if it worked or not. Thanks very much
      • fabiosoares
        • Jul 2015
        • 9
        Problem solved!
        Edited Zabbix user in the / etc / passwd / was:
        zabbix: x: 1000: 1000 :: / home / zabbix: / bin / false
        Changed to:
        zabbix: x: 1000: 1000 :: / home / zabbix: / bin / bash
        And copied the script to / home / zabbix / gave permissions and work
        I hope to help those who have the same problem one day.
