How to monitor a company linux PC with zabbix?
  • gzsun
    • Jul 2015
    Hi, guys,
    Now I am studying zabbix , during my study I have encounterd a problem about monitoring hosts.The issue is that I have two linux servers, one is for zabbix server with public static IP , the other is for zabbix agent which has a private IP like 192.168.x.x/24. For my situation, could I use the zabbix server to moniter zabbix agent ? The topology is like that :
    zabbix agent------Gateway-----Internet-----zabbix server
    (192.168.x.x) (static public IP)
    Can everyone give me the help , thank you in advance !
    Sincerely greetings
    ps: Gateway do not support DNAT,but zabbix agent can access to zabbix server.
  • Colttt
    • Mar 2009
    • 878
    thats quiet easy, use you zabbix agent as active agent, then the agent ask the server what to monitor
    Debian-User
    Sorry for my bad english
    • gzsun
      • Jul 2015
      Hi,Colttt,
      Thank you for your reply, I think your advice is good for me .This morning, I tried to configure zabbix agent as active agent , but in the end I got a feedback from zabbix agent log said "no active checks on server [zabbix server IP:10051]: host [zabbix_agent] not found" . I took this confusion and checked on the configuration profile of zabbix_agentd.conf. Unluckly I didn't find something wrong because only two items were modified:
      ServerActive=zabbix server IP
      Hostname=zabbix_agent
      At zabbix server browser web , I have enabled auto-registration. I also can see the host called "zabbxi_agent" was added to host menu , but the word "Z" 's color is red . What should I do at next step , does the auto-registration is necessary on my lab ?
      Thank you again !
      Best,
      gzsun
