Custom Interval seems to be not working
  • vitS
    • Apr 2021
    • 43
    Zabbox 5.0
    I created simple trigger to check if file was modified at least ones last 12 hours:
    Item
    vfs.file.time[/file/name,modify]
    Used Zabbix_agent ( As I know on Zabbix agent Active custom Intervals not working )
    Update Interval: 10s
    Custom Intervals: Schedulling with value: h00,12 (tried: h0,12 also h12 )
    Trigger
    {server:vfs.file.time[/file/name,modify].fuzzytime(43200)}<>0
    Enabled:
    It is fires alarm - I checked last 12 hours file was modified, but it should be run 12:00 or 00:00
    Please, tell me what am I doing wrong?
    Thanks,
  • vitS
    • Apr 2021
    • 43
    Thank You,
    Alarms are cleared after updates to 0 ( Sorry, missed it in documentation )
    Will check if trigger starts night time, but I think will be OK.
    Thanks again,
      Set update interval to 0.
      as per docs.. @Scheduling intervals are used to check items at specific times. While flexible intervals are designed to redefine the default item update interval, the scheduling intervals are used to specify an independent checking schedule, which is executed in par...
