Help - Zabbix Integration with OpsGenie
  • daniel4987
    • May 2021
    Hello everybody.
    I'm having trouble integrating my zabbix with opsgenie.
    I followed the documentation below, but without success.
    When performing the test, the following message returns to me.
    Detalhes Media type test failed.
    • TypeError: undefined not callable (property 'log' of [object Object])
    • at [anon] (duktape.c:65639) internal
    • at [anon] (function:142) preventsyield
    My settings:
    Zabbix
    Configured: Actions
    Media types: dedicated user for opsgenie
    opsgenie_api: https://api.opsgenie.com/v2/alerts
    opsgenie_token: f7409a5b-fef6-408c-9c94-******
    opsgenie_web: https://danielopsgenie.app.opsgenie.com
    zbxurl: http://192.168.88.247/zabbix
    zbxuser: opsgenie
    Global Macro: {$ZABBIX.URL} Value: http://192.168.88.247/zabbix
    In the OpsGenie, i followed this documentation:
    Create an API integration | Opsgenie | Atlassian Support
    Has anyone else been there?
  • perqvind
    • Mar 2021
    • 22
    Hi
    Did you manage to sort this out? I have the same issue with MS teams https://www.zabbix.com/forum/zabbix-...-0-12-ms-teams
    • derli1988
      • Apr 2021
      • 60
      I myself integrated Opsgenie with Zabbix not via the API but with e-mail, it works perfectly.
      That might give you an idea and possibly a workaround... integrate it with Email, instead.
      For MS Teams, you basically only need the teams_endpoint
