Not Supported ITEMS
  • eli-b
    • May 2021
    Not Supported ITEMS
    Monitoring ESX servers with several servers. some of the servers in the same site are monitored fine and some are not.
    The servers that are not monitored correctly show in items section "Not Supported"
    ALL The servers are linked to template "Template Virt VMware Hypervisor"
    The FW ports are checked and passing throw the communication between the zabbix server and the ESX servers
    Any Ideas ?
  • Cameron94
    • Apr 2021
    • 14
    Do you have a Vcenter in your Enviroment?
    if you check the unsupported item in Latest Data you should get more explanation on error. (remember to check mark both show detail and show
    Show items without data )
    for a complete guide visit this link
    • eli-b
      • May 2021
      Yes we have a vcenter.
      The message that appears in some of the items is "Cannot evaluate expression: "Cannot evaluate function "last()": item "4c4c4544-0033-4b10-8033-b4c04f423333:vmware.hv.hw.cpu.total[{$URL},{HOST.HOST}]" not supported."."
      On other "Unknown hypervisor uuid"
      • Cameron94
        • Apr 2021
        • 14
        I also have a similar issue on zabbix 5.0.9 which I was not able to resolve. it is recommended to use the latest version of zabbix.
        did you check the link that I mentioned? have you tried the method it suggests?
        • eli-b
          • May 2021
          I have checked the link but as I mentioned the template works fine with other servers so it should work fine on other servers that use this template and new added servers
          Did someone suffered from this situation before and fix it?
