Invalid Second Parameter
  • cb0n3y
    • Feb 2021
    • 32
    Hello everyone,
    i'm getting an issue with some Zabbix Proxies that i cannot explain to myself. What am i doing wrong? I just took the default Template and added to the Proxy Host but it doesn't work at all.All items work fine except this two. If you need more information, please let me know. Thank you.
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    Since this particular proxy is Passive it doesn't have the "data sender" and "heartbeat sender" processes running, which are part of Active proxy.
    • cb0n3y
      • Feb 2021
      • 32
      Hello dimir,
      thank you for your answer and time. But i still have a question. Do this match also when the Proxy is being used for both cases: passive and active?
      • dimir
        Zabbix developer
        • Apr 2011
        • 1080
        Sorry, but that's not possible for single proxy. Proxy is working in either passive or active mode, never both at the same time.
        • cb0n3y
          • Feb 2021
          • 32
          Oh, i understand. Thank you.
          • dimir
            Zabbix developer
            • Apr 2011
            • 1080
            You can disable the annoying notsupported items on a host level.
            • cb0n3y
              • Feb 2021
              • 32
              Hi dimir,
              sorry for late answer. I did what you said and evrything is fine. Again. Thank you.
