Can both LDAP and SAML authentication methods be enabled?
  • wyang
    • Mar 2016
    • 93
    Can both LDAP and SAML authentication methods be enabled for Zabbix user authentication?
    If both LDAP and SAML methods consume LDAP and SSO services from a same central authentication service provider, i.e., each user have a same username for both LDAP and SAML, how to configure users and groups in Zabbix for this case?
    Thanks very much!
  • wyang
    • Mar 2016
    • 93
    The questions come from that we would like to enable both LDAP and SAML for user authentication.
    I found that a user needs to be defined as Frontend access type internal with a password. Then, when SAML is well defined, this user has a choice to authenticate via SSO.
    Thus, the default authentication method should be set to internal
    In the meanwhile, if I want to allow LDAP authentication, a user needs to be defined with explicitly defining Frontend access type LDAP.
    That means if I need to allow both LDAP and SAML authentication methods for a human user, I have to create two users in Zabbix for a human user.
    As I cannot create two Zabbix users with a same username (alias), I have to create two usernames for a human user to use either LDAP or SAML authentication methods.
    Please correct me. Thank you very much.
    • wyang
      • Mar 2016
      • 93
      Tested on another staging environment where Zabbix server / web front end are not containerized but installed directly from packages.
      A user is created in a group that is explicitly defined with LDAP frontend access, while LDAP authentication is not enabled. SSO works for the user.
      cyber , I thus got your point "Whatever auth method you use, it just authenticates user." Thanks very much.
        • 4996
        In zabbix you still configure all users/groups as needed. Whatever auth method you use, it just authenticates user. All permissions are maintained inside Zabbix.
