Zabbix Link utilization in %
  • Fotis
    • Sep 2014
    • 24
    Hello all,
    I'm already familiar with net.if.in and net.if.out items, and now i would like to monitor the linkspeed which will help me to check the link utilization in %.
    Anyone has any idea on how to implement this?
    Thanks and regards,
    Fotis
  • Colttt
    • Mar 2009
    • 878
    i think you must use a calculated item.
    you speed/total speed*100
    Debian-User
    Sorry for my bad english
    • Fotis
      • Sep 2014
      • 24
      And how will you give a value to the total speed? Sometimes it might be 1000Mb/s, or 100Mb/s or 10Mb/s...
      • timbo
        • Sep 2013
        • 50
        Hi Fotis,
        Sorry for the late response. Colttt has suggested the right method - if you want to hard code the "total speed" in each calculated item, for each host you want to monitor. But I presume you would like to set this up in a template - so the bandwidth could change depending on the system/device the template is applied to?
        If that is the case, you need to look into Macros:
        Take note of the precedence.
        So, you'd create the template with the calculated item Colttt suggested but with a macro (e.g. {$BANDWIDTH}) in place of the "total speed". You'd add the "{$BANDWIDTH}" macro to the template (typically with the most likely bandwidth in use - e.g. 1000), then on the host level you would add macros as the exceptions (e.g. 100, 10).
        Template Macro:
        {$BANDWIDTH}=1000
        1st Host Macro
        *NOT SET* (means it will inherit the template macro value of 1000)
        2nd Host Macro:
        {$BANDWIDTH}=100
        3rd Host Macro:
        {$BANDWIDTH}=10
        (note: I've used Mbps in the above examples - it's better if you use bps)
        I use this method on various WAN links, each with different bandwidth capabilities.
        You can then set triggers when the Bandwidth utilisation exceeds 90% - for example.
        Hope this helps.
        -Timbo
