SSH Agent in router Huawei
  • SixArt
    • Jul 2015
    • 22
    I try to get configuration of router with SSH Agent in Zabbix,
    I create an item with SSH Agent type and in command form I put this:
    screen-length 0 temporary
    display current-configuration
    This not work, isn't "not supported" and in log (level 4) I don't see any problem.
    Is possible get this router configuration with SSH Agent?
    Regards,
    Dario
  • doncelab
    • May 2015
    • 36
    Also faced the same problem. From the server itself, under the credentials that enter zabbix via sshd. Zabbix itself also logs into the router (this can be seen from the logs on the device), but it seems that it does not receive data from the console. Can I enable debug ssh on zabbix?
    The problem was that you need to add to the command display current-configuration | no-more, it was confusing that there is no support.​
