How can i create trigger threshold 90% for Process CPU utilization?
  • pmurtey
    • Mar 2020
    • 91
    Hi All, We are trying to determine what the correct trigger would be for a process we are monitoring for cpu utilization. We have the item for the process set up as proc.cpu.util[,,,SLBmonitor] at the host inventory level and it is giving us the correct current cpu utilization for the process. How do we set the trigger to alarm if the process exceeds 90 percent for 3 occurrences? And can this be done at the host inventory item/trigger level without creating templates as suggested at https://www.burlutsky.su/monitoring/...th-hysteresis/.
  • derli1988
    • Apr 2021
    • 60
    If this is a windows host you're trying to monitor, first make sure you have an item to detect the cpu, usually, this item is already in the default template Template Module Windows CPU by Zabbix agent, the item name is CPU UTILIZATION.
    Then, you create a trigger like the one below:
    {Host_name:system.cpu.util.min(5m)}>{90}
    It would be something like this
    • pmurtey
      • Mar 2020
      • 91
      This is a Linux system. So this is saying not to alert until the process has exceeded 90% utilization for 5 minutes?
      • pmurtey
        • Mar 2020
        • 91
        I tried {v00serverc01/:/proc.cpu.util[LBservice].min(5m)}>{90} and we get this message back "Incorrect trigger expression. Check expression part starting from ">{90}".
        • derli1988
          • Apr 2021
          • 60
          What I have for my Linux systems is:
          {Linux server:system.cpu.util.min(5m)}>{$CPU.UTIL.CRIT}
          $CPU.UTIL.CRIT being a macro with value 90.
          It works all the time.
            • 4996
            Remove {}-s from the 90.
