I can only validate in zabbix via web from localhost
  • amarquez
    • May 2021
    Good afternoon,
    I have a zabbix 4.2.5 that I cannot validate in the system if it is not by mounting a reverse tunnel to localhost ... When trying to access with a valid user, I get the following message: "You are not logged in You must login to view this page. If you think this message is wrong, please consult your administrators about getting the necessary permissions. ". If I try to access with an incorrect username / password, the system tells me that the username / password is incorrect ... so the query to the DB is done correctly.
    Any idea where the problem is coming from?
    Thanks!
