Install Zabbix without ROOT privileges is it possible?
  • propusgemini@gmail.com
    • Mar 2018
    • 108
    Reading here it's possible!
    really?
    There are problems with this installation?
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    By default it's designed to run as non-root, so if you just get the packages from https://zabbix.com/download it will run as non-root (but as user zabbix).
    • dimir
      Zabbix developer
      • Apr 2011
      • 1080
      Oh, sorry, confused "running" with "install". :-D
      It is not a problem to download the binaries (or compile them) and run them as any user. E. g.
      ~/bin/zabbix_server -c ~/conf/zabbix_server.conf
      You only need to make sure that user has access to the resources specified in the configuration file, e. g. LogFile, PidFile, SocketDir etc.
        Nowhere in that linked page is said, that you can install it without root permissions.......
