system.run powershell command with Zabbix Agent Active
  • Cristianssenn
    • May 2021
    Hello gents.
    I just wanted to know if there is a limitation of Zabbix in using a key with a powershell command, like:
    Type: Zabbix Agent (active)
    Key: system.run[powershell.exe -command "get-ClusterGroup | Select Name | ConvertTo-Json -Compress"]
    Info: Text
    The only value that I receive is:
    On the host, the command returns the json with the correct values.
    PS: I tried with different combinations of quota, double quota and escape characters and none worked. But, maybe I miss something...
    PS2: I'm not interested in using a PS script deployed on each host.
    Thanks.
  • lgros
    • Jun 2023
    I don't know if this is still relevant, but this is how I did it
    system.run[[powershell.exe -NoProfile -ExecutionPolicy Bypass -Command "@{data=@(Get-ClusterGroup |Where-Object {$_.Name -ne 'Available Storage' -and $_.Name -ne 'Cluster Group'}|Select-object @{n='{#ROLENAME}';e={$_.Name}},@{n='{#ROLEID}';e={ $_.Id}})}|ConvertTo-Json -Compress"]]
    the double square brackets are valid.
