n/mysqld/mysqld.sock' (2)
1547:20210331:122902.491 database is down: reconnecting in 10 seconds
1547:20210331:122912.491 [Z3001] connection to database 'nmonitor_prod' failed: [2002] Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
1547:20210331:122912.491 database is down: reconnecting in 10 seconds
1547:20210331:122922.492 [Z3001] connection to database 'nmonitor_prod' failed: [2002] Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
1547:20210331:122922.492 database is down: reconnecting in 10 seconds
1547:20210331:122932.492 [Z3001] connection to database 'nmonitor_prod' failed: [2002] Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
1547:20210331:122932.492 database is down: reconnecting in 10 seconds
1547:20210331:122942.492 [Z3001] connection to database 'nmonitor_prod' failed: [2002] Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
1547:20210331:122942.492 database is down: reconnecting in 10 seconds
1547:20210331:122952.549 database connection re-established
1547:20210331:122954.745 current database version (mandatory/optional): 05000000/05000002
1547:20210331:122958.007 database is not upgraded to use double precision values
1466:20210331:123829.539 current database version (mandatory/optional): 05000000/05000002
1466:20210331:123833.610 database is not upgraded to use double precision values
3612:20210331:125553.331 current database version (mandatory/optional): 05000000/05000002
3612:20210331:125553.331 starting automatic database upgrade
3612:20210331:125725.244 completed 1% of database upgrade
3612:20210331:125725.376 completed 2% of database upgrade
3612:20210331:125725.872 completed 4% of database upgrade
3612:20210331:125725.876 completed 5% of database upgrade
3612:20210331:125730.711 completed 7% of database upgrade
3612:20210331:125817.633 completed 8% of database upgrade
3612:20210331:125820.452 completed 10% of database upgrade
31:125940.219 completed 91% of database upgrade
3612:20210331:125941.617 completed 92% of database upgrade
3612:20210331:125943.156 completed 94% of database upgrade
3612:20210331:125946.255 completed 95% of database upgrade
3612:20210331:125952.385 completed 97% of database upgrade
3612:20210331:125952.737 completed 98% of database upgrade
3612:20210331:125952.741 completed 100% of database upgrade
3612:20210331:125952.741 database upgrade fully completed
3612:20210331:125952.756 database is not upgraded to use double precision values
2053:20210331:132340.015 current database version (mandatory/optional): 05020000/05020000
2053:20210331:132350.199 database is not upgraded to use double precision values
Binary file (standard input) matches
what is the issue?
what is the issue?
