DB connection error
  • motitest
    • Nov 2020
    DB connection error
    What can I do?
  • Atsushi
    • Aug 2013
    • 2028
    Did you load the initial data? Did you load the create.sql.gz file into the database for Zabbix if you installed using the package?
