is there any solution for monitoring applications with Zabbix Agent that are running under Kubernetes?
I tried to build an image using RabbitMQ image and by writing Dockerfile where Zabbix Agent is installing. I have some problems with that and that's why I'm asking.
Is there any different way to monitor RabbitMQ with plugins using Zabbix Agent? If not, are you able to help me with that? It would be awesome to build other apps with Zabbix Agent that are running under Docker/Kubernetes.
