Create Geographic Type Map ??
  • btrout
    • Oct 2006
    The screenshot page has a map that looks like the country change color when an alarm is present.
    Am I reading into it ?????????
    If not, how in the world is this done?
  • charles
    • Sep 2004
    • 54
    This wouldn't be too hard using the google maps api. The hardest part would be making overlays for each country. You'd draw one colored overlay for each contry and use ajax to poll zabbix (probably your own code to query the alarm table) and change the overlay to a different colored one if you had an alarm, and back when it cleared.
    hth
    charles
    • dantheman
      • May 2006
      • 209
      I don't recall where, but there is a post on the forum that walks you through how to setup a map like the one picture of the zabbix website. Try doing a little searching.
