Unable to run system.run[]
  • zbxksiu123124
    • May 2021
    Dear All,
    I would like to execute a ps1 script to return some text from my Windows machine.
    So I add an item to Windows host, as below
    system.run[powershell -NoProfile -ExecutionPolicy bypass -File "\\myshare\myscript.ps1",1]
    However, it doesnt work, it shows not supported in host page and Unknown metric system.run.
    Tried to added to AllowKey = system.run[*] in agent conf file, but still now working.
    Any ideas?
    Best Regards
  • RaulChiarella
    • Apr 2021
    • 59
    I am having the same problem
    Using Zabbix Agent 2 - Trying to do this on Windows 10...
    Did you get it working?
    • Daniel4711
      • Jul 2014
      • 126
      Same Problem here with an SQL Template.
      Key: system.run["powershell C:\'Program Files'\'Zabbix Agent 2'\scripts\database_status_disc.ps1 -instName 'PROD' -dbName 'tempdb'"]
      Info: unknown metric system.run
      Zabbix 5.4.7
      Agent 2 5.4.7
      Any Ideas?
      • Daniel4711
        • Jul 2014
        • 126
        Reading and understanding (!) the documentation helped me.
        # If no AllowKey or DenyKey rules defined, all keys are allowed.
        # Unless another system.run[*] rule is specified DenyKey=system.run[*] is added by default.
        Example:
        AllowKey=system.run["powershell C:\'Program Files'\'Zabbix Agent 2'\scripts\database_status_disc.ps1 *"]
        • RaulChiarella
          • Apr 2021
          • 59
          Example:
          You're a lifesaver!
