Unacknowledged issues
  • zuize411
    • Jun 2021
    I'm discovering Zabbix. Sorry, if my question is dumb.If it is, I'm sure I'll have a quick and easy answer.
    I need to know I can see all unacknowledged issues, and maybe filter that view for a certain hosts group, a certain host, ...
    None of the view I found are fit for monitoring operators, with a large amount of hosts/items.
  • Atsushi
    • Aug 2013
    • 2028
    It can be displayed using the filter function. You can filter by specifying multiple conditions such as host group and host.
