Trigger - test for value 0
  • norbhinn
    • Jun 2021
    I'm trying to make a trigger that checks if an snmp value have been over 0 at one point for instance last 24 hours. So i figured that I will du sum() and test last 24h for 0. If sum() is still 0, then trigger. The issue is that when I apply the template the trigger ignores that it actually do not have enough sample to trigger this issue. If the last value is 0, its seems like it assumes that all no data is also 0, and trigger an alarm.
    So, how do I make zabbix take into account that it actually do not have enough samples to trigger?
    sum(/template/key[{#SNMPVALUE}],24h) = 0
    Thanks!
  • Markku
    • Sep 2018
    • 1784
    Hi, do you have the same problem if you use max() instead of sum()?
    Markku
    • Semiadmin
      • Oct 2014
      • 1625
      max(/template/key[{#SNMPVALUE}],24h) = 0 and last(/template/key[{#SNMPVALUE}],#1:now-1d) >= 0
      • norbhinn
        • Jun 2021
        Only max did not work, but 'Semiadmin' solution did work. I noticed that my original post might be a bit confusing. The trigger should be fired if the value the last 24h have all been 0. The alarm clears if the last value is more then 1.
        Q: Why did you put >= 0 in the last statement?
        Trying to understand the last statement, is it correct that it test the first value 1 day ago? And should it be = 0 to achieve my objective?
        Thanks!
        • Semiadmin
          • Oct 2014
          • 1625
          It's a fake condition, and it is always true. But this condition prevents the trigger from being fired prematurely.
          • norbhinn
            • Jun 2021
            Aha, ok, thanks! Its working great now.
            • Markku
              • Sep 2018
              • 1784
              I think I'm learning here now... So the idea of last(/template/key[{#SNMPVALUE}],#1:now-1d) >= 0 is that if there is no data for the value 24h ago (as required by the expression), the last() function evaluates to *undefined* (or something like that, ie. not ">= 0") and the trigger does not trigger?
              Markku
              • Semiadmin
                Semiadmin commented
                yes, the trigger goes to the state "Unknown"
