Monitor from RIPE measurement
  • lvfranz
    • Jun 2021
    • 10
    Hi want monitor latency and packet loss using RIPE measurement.
    This is and example of the retrieved data from ripe api https://atlas.ripe.net/api/v2/measur...7/status-check
    I think I need to create an LLD discovery rule to create probes object and than retrive data from json but I have no idea how to do
  • lvfranz
    • Jun 2021
    • 10
    Ok, and how can i create dynamic object of the probes?
    This is a part of the retrived json, and probes number are as a array name not property.
    • lvfranz
      • Jun 2021
      • 10
      I can chose number of probes to be used and region, than used probe are automatically choosed from available. While measurement are running, probes can change if one goes offline.
        If that page returns json formatted data, you don't need LLD. A http item and some dependent items should do the trick.
        Examples can be found
          ok .. right.. Not familiar with that RIPE thing... Initial click on link lead me to believe there is just single set of data......
