Monitoring LDAP with BIND DN
  • Mr_Diba
    • Jun 2021
    I have a hard time figuring out how to monitor a LDAP server without anonymous bind using the simple check net.tcp.service.
    The setup:
    LDAP server monitored by zabbix-agent2
    LDAP configured to listen on port 636 with SSL certificate and anonymous bind disabled.
    I have a BIND DN user and password but I have no idea how to configure them.
    The current expression:
    max(/ldap.example.com/net.tcp.service[ldap,ldap.example.com,636],#3)=0
    always result in a false because it is not being able to do a search.
    So, is it possible to add the BIND DN user to the search?
