Zabbix newbie, need help monitoring Ubuntu services
  • Zyklon
    • Aug 2015
    Hello
    I would like to know how can I monitor any service that is running in ubuntu, should I create a user parameter for monitoring such services that are not displayed on zabbix itens?
    here is a example of a service that i want to know if its up/down
    root@myserver:~# service SampleAPP status
    SampleAPP start/running, process 21008
    how to make zabbix monitor it?
  • jamesNJ
    • Jun 2015
    • 103
    You could try either a user parameter, or use the proc.num[] key to look for running processes.
    • Zyklon
      • Aug 2015
      but how to create such user parameter?
      thats my question ...
      • jamesNJ
        • Jun 2015
        • 103
        See the following:
        You will need to know a little about linux command line to craft a test that you are interested to see.
        For example, if I wanted to see if mysqld process was running, I could use something like:
        UserParameter=mysq.proc,ps -ef | fgrep "/usr/libexec/mysql" | fgrep -v grep
        (my system is centOS 7, yours might be different) That item should return a single line for the mysql process, and you could then use the nodata or regex trigger functions to alert you if that query turns up empty.
