File System Discovery Filter
  • sxm1my
    • Aug 2012
    • 12
    All of a sudden my filter for excluding drives from being monitored is no longer working. No changes made that I am aware of. Is this syntax not correct?
  • Markku
    • Sep 2018
    • 1784
    Your regex looks weird, so please test it with f.ex. https://regex101.com/ if it does what you want it to do.
    If you happen to want it to match with everything but strings starting with P or X (just guessing here), then "^[^PX]" would be my attempt, which means "start of string and then anything but P or X".
    Markku
    • sxm1my
      • Aug 2012
      • 12
      Thanks. I will give that a try.
        Wouldn't it be easier to do "not matches" and either "^P|^X" or "^[PX]"? or as Markku suggested, matches "^[^PX]
        Current one does a bit more than expected, I think. It excludes everything that starts with P or | or ^ or X in the beginning of a line.
