ICMP Response time in zabbix
  • mansourh12120
    • Jun 2021
    • 10
    Hi every one
    i'm trying to undrestand how macro {ICMP_RESPONSE_TIME_WARN} in zabbix is working and what is means
  • Atsushi
    • Aug 2013
    • 2028
    Probably the macro set in the template. Try opening the settings for the appropriate template and clicking the Macros tab. I think the value of that macro is set.
    ex. Template Module ICMP Ping
    • mansourh12120
      • Jun 2021
      • 10
      Thanks dear!
      • mansourh12120
        • Jun 2021
        • 10
        hello every body!
        i created a file in externalscript and wrote below script in it
        #!/bin/bash
        packetloss= 'ping -q -i0.30 -n -s 50 -c5 ${1} | grep "packet loss" | cut -d " " -f6 | cut -d "%" -f1
        [ -z "$ {packetloss}" ] && packetloss=100
        echo "${packetloss}"
        now i create an item with key packetloss(script file name) but i get this error" value of type "string" is not suitable for value type(float)".value "connect:invalid argument
        thanks
        • derli1988
          • Apr 2021
          • 60
          Just create an item on the host you want to monitor, the item should be exactly like the one on the screenshot
          Change the x.x.x.x with the IP you want to to get response times.
