packetloss
  • mansourh12120
    • Jun 2021
    • 10
    packetloss
    Hi to all!
    Does anyone have a script for Packet Loss in zabbix?
  • vitS
    • Apr 2021
    • 43
    For example:
    UserParameter=pLoss,ping -q -i 0.50 -n -s 50 -c5 IPaddress | grep "packet loss" | cut -d " " -f7 | cut -d "%" -f1
    Will be in result 0.0 -> Trigger more then 20 - Alarm
    Maybe it will help You,
    Thanks,
    • mansourh12120
      • Jun 2021
      • 10
      Thanks,but it doesn't work correctly!
      • vitS
        • Apr 2021
        • 43
        What do You mean?
        [root@server /]# ping -q -i0.30 -n -s 50 -c5 ip | grep "packet loss" | cut -d " " -f7 | cut -d "%" -f1
        0.0
        • mansourh12120
          mansourh12120 commented
          I run it but don't display any result.
      • vitS
        • Apr 2021
        • 43
        Just a question: did You replace ip with real ip in: [root@server /]# ping -q -i0.30 -n -s 50 -c5 ip | grep "packet loss" | cut -d " " -f7 | cut -d "%" -f1
        I mean:
        [root@server /]# ping -q -i0.30 -n -s 50 -c5 127.0.0.1 | grep "packet loss" | cut -d " " -f7 | cut -d "%" -f1
        Thanks,
        • mansourh12120
          yes yes i replace my ip with "IP"
      • vitS
        • Apr 2021
        • 43
        Try to play with these flags:
        Starting with simple ping:
        And then add flags by one:
        5 packets transmitted, 5 packets received, 0.0% packet loss
        • mansourh12120
          Thank you very much dear friend, the problem was solved.
      • mansourh12120
        • Jun 2021
        • 10
        hello every body!
        i created a file in externalscript and wrote below script in it
        #!/bin/bash
        packetloss= 'ping -q -i0.30 -n -s 50 -c5 ${1} | grep "packet loss" | cut -d " " -f6 | cut -d "%" -f1
        [ -z "$ {packetloss}" ] && packetloss=100
        echo "${packetloss}"
        now i create an item with key packetloss(script file name) but i get this error" value of type "string" is not suitable for value type(float)".value "connect:invalid argument
        thanks
          Why would you need a script, if there is a built in functionality?
