Dockerized agent2 disconnection
  • Amiram
    • Feb 2021
    • 68
    Hey,
    I'm having some trouble with the zabbix_agent2 docker version 5.4 latest version.
    I'm missing a lot of data at the server (discontinuous graphs) and I can see that the agent is not avaliable.
    I use PSK encryption between the zabbix_agent2 and the zabbix_server and I can see the following error at the docker logs.
    cannot process incoming connection *********error****** SSL routines:tls_psk_do_binder:binder does not verify:../ssl/statem/extensions.c:1618:
    Please help
  • Amiram
    • Feb 2021
    • 68
    Found it.
    The reason for this issue was the fact that I used the same PSK identity to the proxy and the agent.
