non-standart use of Zabbix
  • ZeratulSC
    • Jun 2021
    Hello, I'm new to Zabbix. I'm trying to figure out its extensive functionality, but I can't find what I need. I have a server running a Zabbix server, as well as several raspberry-like devices, each behind its own router. Every device (not a router) runs an executable software. Its purpose is in the processing of sensors, the calculation of data from them, transmission over industrial protocols further over the network, in addition, a server is deployed on the device and a web interface is written for local access to information on the device. I have the following questions, I will be very grateful for the answers:
    1) What calculating power does the Zabbix agent require? If possible, you can make a comparison with any working utilities (the reason for the question is the very capacious calculating power of devices)
    2) Access to the web interface is possible by the following methods
    ◦ JSON-RPC 2.0 over HTTP
    ◦ JSON-RPC 2.0 over TCP
    Unfortunately, in the help I found the use of json-rpc only in the direction of the zabbix server. Is it possible to send rpc requests towards the monitored device?
    3) I saw the possibility of using the ssh protocol. Can you use it to execute commands on the device and then upload files from it?
