Count total amount of problems/alarms for a given period
  • markfree
    • Apr 2019
    • 875
    Hi guys.
    For Zabbix 4.4.4
    I'm trying to simply count the number of alarms/triggers occured in a given period but the "Problems" tab only finds "1000+".
    I just wanted to count the amount of problems solved for a given period. For example: total amount for April.
    If I try to export the list, it won't export everything, just 1001 alarms.
    Any idea on how to collect that number?
  • markfree
    • Apr 2019
    • 875
    After updating my search limit to 20000, I was able to gather the correct amount of triggers shown at "Problems" tab.
    Thank you cyber
    Still, I hope there's a better way to do this kind of search.
    Later I'll be looking more into this. Maybe a DB query might do the trick.
      Administration -> General -> Limit for search and filter results...
