Zabbix proxy issue with old connection
  • rfonvig
    • Mar 2021
    Ive got a zabbix server that runs with 1 proxy @ "192.168.2.x", but before i connected to the "real" proxy i testet with a test lab envrioment runnign on "192.168.5.x", the new proxy setup works perfect, but in my log i keep getting this error
    1318:20210621:115257.736 cannot parse proxy data from active proxy at "192.168.5.100": proxy "zabbix_proxy01" not found
    ive looked in almost evey entry in the maridb for old connections and in the gui, but i cant seem to find any entry trying to connect to the old proxy which is deleted, what am i missing ?
  • Markku
    • Sep 2018
    • 1784
    Hi, according to the log you presented there is a Zabbix proxy at IP address 192.168.5.100 that tries to communicate with the Zabbix server. So there is no apparent problem in your Zabbix server configuration but you need to stop/remove the Zabbix proxy that you used for lab testing.
    Markku
