SNMP Uptime
  • perqvind
    • Mar 2021
    • 22
    SNMP Uptime
    Hi
    Is anyone using SNMP to pull the uptime of a host and pull that into a report? we need to pull uptime reports from Windows hosts using the zabbix api, we will be using a powershell script once we have a clue how to pull the data.
    Regards
    Per
  • derli1988
    • Apr 2021
    • 60
    Can't you use the zabbix agent?
    • perqvind
      • Mar 2021
      • 22
      No it needs to come via SNMP also it's Veeam related
