Hello
I'm solving a problem with my own sms gateway. If I upload the php file to the var/www/html directory and run it. sms me pride ascript works.
When I copy it to the directory /usr/lib/zabbix/alertscripts, it throws me an error
appliance@zabbix:/usr/lib/zabbix/alertscripts$ ls -l
Can you advise where I make a mistake? why can't i do it
HTTP/1.1 200 Ok Server: Ethernut 4.9.10.0 Content-Type: text/xml Content-Length: 290 Connection: close 1 1
sh: 1: /usr/lib/zabbix/alertscripts/gwtp.php: not found
-rwxrwxrwx 1 zabbix zabbix 1100 Jun 22 15:05 gwtp.php
#!/usr/bin/php
<?php
$type = "SMS";
$nmr = $_SERVER["argv"][1];
$nmr1 = $_SERVER["argv"][2];
$text = $_SERVER["argv"][3];
$host = "192.168.35.252";
$port = 80;
$user = "admin";
$pass = "password";
$xml = "<soapenv:Envelope xmlns:soapenv=\"http://schemas.xmlsoap.org/soap/envelope/\">
<soapenv:Header/>
<soapenv:Body>
<pos:QueueAdd>
<Queue>GsmOut</Queue>
<Gsm>
<Cmd>".$type."</Cmd>
<Nmr>".$nmr."</Nmr>
<Text>".$text."</Text>
</Gsm>
</pos:QueueAdd>
</soapenv:Body>
</soapenv:Envelope>";
$fp = @fsockopen($host, $port, $errno, $errstr, 30);
if (!$fp) {
echo "$host:$port: $errstr ($errno)\r\n";
else {
fwrite($fp, "POST /service.xml HTTP/1.0\r\n");
fwrite($fp, "User-Agent: MyPHPTest\r\n");
fwrite($fp, sprintf("Host: %s\r\n", $host));
fwrite($fp, sprintf("Authorization: Basic %s\r\n", base64_encode($user . ":" . $pass)));
fwrite($fp, sprintf("Content-Length: %d\r\n\r\n", strlen($xml)));
fwrite($fp, $xml);
while (!feof($fp)) {
echo fgets($fp, 128);
fclose($fp);
