I have LLD for users on GPON device
I check their status via LLD and fire two triggers for LOS and dying-gasp
for example
user 1 status - ok
user 2 status - LOS
user 3 status - dying-gasp
and so on (every device being discovered for number of connected users)
And I need to somehow create a trigger with higher severity to be created only if there are more than X users with dying-gasp or LOSI on this device
If there is any way to do it with tags maybe? I couldn't find any good examples in google
for example
user 1 status - ok
user 2 status - LOS
