Remote Commands + Proxy
  • mfortes
    • Oct 2019
    • 418
    Friends, My question:
    Remote commands configured in an action, are executed on hosts monitored by proxy? The proxy who executes the commands? And any version, or is it from a specific one...
    Michael R. Fortes
    Linkedin: Mike Fortes
    Medium: mromeiro-f
  • markfree
    • Apr 2019
    • 874
    According to Remote Commands doc,
    Remote commands can be executed by Zabbix server, proxy or agent. Remote commands on Zabbix agent can be executed directly by Zabbix server or through Zabbix proxy. Both on Zabbix agent and Zabbix proxy remote commands are disabled by default.
    The way I see it, remote commands can be executed on either Server, Proxy or Agent. That will depend on where you're trying to execute an action.
    • mfortes
      • Oct 2019
      • 418
      I want to run the command on the final host, a windows for example... Monitored via proxy...
      Today when I try to run a remote command, Zabbix is ​​ignoring the proxy and trying to run the command directly from Zabbix Server... But it needs to go through the proxy to see the host
      Michael R. Fortes
      Medium: mromeiro-f
      • markfree
        • Apr 2019
        • 874
        Have you enabled agent's remote command?
        They can be enabled by:
        • adding an AllowKey=system.run parameter in agent configuration;
        • setting the EnableRemoteCommands parameter to '1' in proxy configuration
        Did you set up the action with "Execute on Zabbix agent"?
        • mfortes
          • Oct 2019
          • 418
          Yeah... but i dont have "Zabbix Server (Proxy)"...
          Which version has this option?
          Michael R. Fortes
          Medium: mromeiro-f
          • markfree
            • Apr 2019
            • 874
            The screenshot above was taken from a 4.4 server.
            But I see what you mean.
            Looking at a 5.4 server, my "operation" tab from "Actions" configuration does not show any "remote command" option. It is locked at "send message".
            For me, the only operation available for "trigger actions" is "Send message", wich is quite odd.
            I only noticed that now.
            According to Operations documentation, it should have "remote command" operation.
            You can define the following operations for all events:
            send a message
            execute a remote command
            • markfree
              • Apr 2019
              • 874
              I found the reason why my "operation" was limited.
              Operations doc says
              <remote command name> - execute a remote command. Commands are available for execution if previously defined in global scripts with Action operation selected as its scope.
              So, it seems remote commands are available through "scripts" configuration under "administration".
              You must configure a script setting its scope as "action operation" and its type as "script", which then shows "execute on" option.
              After that, your new script should appear at "operation" box under "operation details".
              Please, see if that helps you.
              • mfortes
                • Oct 2019
                • 418
                My Zabbix Server is too old... I dont have any of this options...
                Thanks 4 the help <3
                Michael R. Fortes
                Medium: mromeiro-f
                • markfree
                  markfree commented
                  What's your server version?
              • mfortes
                • Oct 2019
                • 418
                3.2.11 at this moment
                Michael R. Fortes
                Medium: mromeiro-f
                • markfree
                  • Apr 2019
                  • 874
                  According to Remote commands documentation version 3.2,
                  Remote commands are not supported to be executed on Zabbix agents monitored by Zabbix proxy, so for commands from Zabbix server to agent a direct connection is required.
                  I would suggest upgrading the server.
