[Help] Trigger only after 3 attemps
  • andvsilva
    • Aug 2020
    • 39
    I'm new in Zabbix and I need help to understand the trigger, because when I test in trigger page works well, but when I put in my env doesn't work, I don't know what to do, I need to solve it.
    Example
    - I have the check in IDRAC for Controller
    - The OK value is 3
    Then, I need to check the last 3 attempts if is different of 3.
    I tried a lof of changes and nothing work, the trigger always run after first attempt.
    My actual configuration is:
    -- Problem Expression:
    ({TD03_IDRAC:RAIDControllerStatus.last(#2)}<>3 and {TD03_IDRAC:RAIDControllerStatus.last(#1)}<>3 and {TD03_IDRAC:RAIDControllerStatus.last()}<>3)
    -- Recovery Expression:
    ({TD03_IDRAC:RAIDControllerStatus.last(#2)}=3 and {TD03_IDRAC:RAIDControllerStatus.last(#1)}=3 and {TD03_IDRAC:RAIDControllerStatus.last()}=3)
    But I don't like because it is too extensive and doesn't work as I expected. So I tried:
    {TD03_IDRAC:RAIDControllerStatus.count(#3,9,gt)} > 9 or {TD03_IDRAC:RAIDControllerStatus.count(#3,9,lt)} < 9
    {TD03_IDRAC:RAIDControllerStatus.count(#3m,9,eq)} = 9
    Someone can help me please? I don't know what to do, I really don't know, because I read the doc: 1 Supported trigger functions [Zabbix Documentation 5.2] and don't understand why doesn't work.
  • Markku
    • Sep 2018
    • 1784
    Hi, note that last() is the same as last(#1), as documented in the doc you linked, so you need to rewrite your "triple-last" trigger. You don't have to configure the recovery expression manually.
    Alternatively you can try "max(#3) <> 3 and min(#3) <> 3".
    Markku
    • andvsilva
      • Aug 2020
      • 39
      Thanks Markku it works as I needed. Thank you so much, maybe there is other ways, but for now is good.
      I read the doc about Min and Max and the idea is:
      - Min: Will trigger if the last 3 values is lower than 3
      - Max: Will trigger if the last 3 values is higher than 3
      Well, I really appreciate your help. Just one question, this will better if put 'OR' instead 'AND' correct?
      I tested in trigger page and works in the both ways. I will do some test to check if works, but what do you think about? I have some difficult to understand the zabbix trigger, when I test in page of trigger (zabbix administration page) it work, but when I test in item (normal thinks for example) doesn't work as I expected.
      • Markku
        • Sep 2018
        • 1784
        min() is the minimum of the provided values (= result is a number), and max() is the maximum accordingly. Example: if the last three values are 3, 2 and 3, then min(#3) is 2 and max(#3) is 3.
        You are correct, my mistake, OR is the correct one here, sorry for any confusion. Yes, it needs to trigger if either the minimum is not 3 OR the maximum is not 3.
        Markku
