Zabbix dashboard graph ugly colors
  • registration_is_lame
    • Nov 2007
    • 148
    Normally you can specify any colors, lines or areas for your graph but not the one on the main DASHBOARD page.
    It seems it only allows you to use 1 gradient of a color for the different lines.
    Is there any workaround for this? (BTW Zabbix 4.0.2)
    • Nov 2007
    • 148
    I have tried that before, however now I found out what the problem was.
    As long as you use macro in the item name like: ($1) VM Connections
    Zabbix will pull hem all into 1 single graph. I have to delete all of these items and recreate them like CONN_MACHINE1 ...
    After this you can separate them
      Add each item as separate dataset and choose your colour... I think its possible in 4.0 also?...
        That widget does pattern matching for hostnames and item names. So it is quite natural, that it puts all items, that match, into one dataset....
