Hello!
I'm quite new to zabbix and I'm trying to configure an "alive" check on my tomcat server.
What I've done is setting up an HTTP agent (pointing to the base page of tomcat) with a trigger: after five minutes of getting no data I send a "restart tomcat" command to the server.
It works till this step: sometimes the problem is solved because my http agent get correctly the page and it end there.
Time to time the http agent seems blocked (I have this message "Cannot perform request: Operation timed out after 10000 milliseconds with 0 bytes received") and it get to work again only if I manually click on the "Check now" button.
I have zabbix 4.2 installed on Ubuntu 18.04.3.
I think I have something misconfigured but I don't know what can it be.
Any advice?
Thanks,
Marco
Any advice?
Thanks,
Marco
