How to filter discovery rule
  • gergely.szocs
    • Jun 2021
    Dear All,
    I am longing for some help with the below issue. I am stuck here for weeks by now. Could you please help me?
    I would like to smart monitor only sda and sdb with the official 'SMART by Zabbix agent 2 Template'. I set things as per below but it did not solve the issue. It keeps monitor sd[c-z]. Can you please help me? Thank you in advance.
    - I created filters in both Discovery rule as per below.
    Disk discovery > Filters
    {#NAME} matches {$SMART.DISK.NAME.MATCHES}
    Attribute discovery > Filters
    {#NAME} matches {$SMART.ATTRIBUTE.ID.MATCHES}
    - After that I modified the existing macros on template level as per below.
    SMART by Zabbix agent 2 > Macros
    {$SMART.ATTRIBUTE.ID.MATCHES} (sd[a-b]).sat
    {$SMART.DISK.NAME.MATCHES} (sd[a-b]).sat
    Thank you in advance,
    Regards,
    Gregory
  • Markku
    • Sep 2018
    • 1784
    Hi, if I understand correctly your problem is that you have modified the LLD filter but Zabbix still keeps monitoring the excluded disks. (There is a possibility for misunderstanding here because I don't do SMART monitoring myself.) This is dependent on the discovery rule setting "Keep lost resources period". It is very common to be set to 14 days or so, and it means that even though LLD is not discovering the items anymore, they will be kept in monitoring that long before being deleted automatically.
    You have two options:
    1. Delete the extra items manually from the host. There should also be an icon on the right saying that the item is not discovered anymore and it will be deleted in X time.
    2. Modify the "keep lost resources period" configuration as you wish.
    With option 2, do think about a situation where you misconfigure the LLD filter (or there is some malfunction in LLD) and your correct items are not discovered anymore. If you set the period too low, the items (and their history data) will be deleted maybe right away.
    I usually keep the period in 14 or 30 or even 90 days (case by case), and delete the old items manually if need arises.
    Markku
    • gergely.szocs
      • Jun 2021
      Markku
      Dear Markku,
      Thank you for your help and for your response. Unfortunately this doesn't solved the problem.
      I think maybe this new template has some issues or bugs. I still try to figure out what's the problem.
      Regards,
      Gregory
