Mute Zabbix alerts so they don't send emails
  • mcgv1
    • Jun 2021
    We have several switches at Zabbix monitored at various locations, each with numerous interfaces that send email alerts in the event of a crash. How would it be possible for Zabbix to only send email alerts from some interfaces (not all) even though the rest continue to be monitored without sending alerts? Attached screenshot where we have configured the action that is responsible for implementing this but for a single switch, what would be the easiest way to include this for each of the switches (there are 400 switches):
    Thank you
  • mcgv1
    • Jun 2021
    Hi Splitek
    Thank you very much for the quick answer, You mean tagging the host and then tagging each of the interfaces that we want to send an alert?
    For example: Tag host
    Label interfaces: (In the triggers of the host that we want to alert):
    And finaly in the action:
    Another option could be this ?: Could we only label all the triggers that we want to alert as “To_alert” and value “yes” and then ask in “actions” only for that label field (without referring to the host)?
    Thank you so much
    Manuel Gonzalez
    • mcgv1
      • Jun 2021
      Thank you so much splitek. Do you know where override rules can be created? I can't find that option in "templates". Now I have another problem, which is that the "tag" field appears disabled in the triggers of the interfaces.
