Filter values from a Graph in the dashboard
  • Wiben
    • Jul 2021
    Hello everybody,
    I have created several charts in my dashboard for some items of my 50 monitored hosts.
    These graphs seem to be focused for only a few hosts, when you put more than 20 it is not possible to identify which one has the highest value. In the pop-up modal it shows "Displaying 20 of 50 found", they are not ordered so it does not show the 20 with the highest value but random.
    Actually the objective I have with these graphs is to see the hosts that have a value above a range, something similar to the operation of triggers, for example cpu over 50%.
    Is it possible to do this in any way?
    I would not like to read the zabbix data from other front ends just because of the deficiency in these charts.
  • JohnYeldell
    • Jul 2021
    Determine an event tag name that will be utilized for occasion relationship.
    This field is shown if 'All issues if tag esteems match' is chosen in the OK property of the occasion closes, in which case this field is required.
