Zabbix web scenario vs F5 ASM Cookie
  • pathos
    • Jul 2021
    Hi everybody,
    We have put in place a web scenario to confirm our internal tool is working.
    The web scenario try to :
    - Access login page
    - Login
    - Check Login
    - Log off
    - Check Logoff
    The application is a python Django application behind a F5 appliance. Django is using a CSRFToken which is retrieve by zabbix web screnario as it should.
    All was OK until a modification was made on our F5 appliance
    On the F5 , HTTP X-Forwarded-Proto header has been activated.
    Since, Zabbix is not able to login to our Django app. It seems F5 appliance is inserting an ASM cookie.
    I'm trying to retrieve this cookie and use it on our web scenario without success
    Has someone experience the same issue or having a similar issue ?
    Many thanks for your help
