Dear All
i run an autodiscovery , to find all network cards installed on my system.
The rule work find and all cards are added to the host. But, some cards are not in use. I want remove all cards called (example) tap1234 , tap5678, usb0 etc.
I have updated the regular expression :
Is it the right way ?? Or not ?! ?
AndreA
1 » ^venet$ [Result is FALSE] 2 » ^lo$ [Result is FALSE] 3 » ^Software Loopback Interface [Result is FALSE] 4 » ^tap$ [Result is FALSE] 5 » ^usb$ [Result is FALSE]
AndreA
