Hi guys.
I've been running Zabbix (currently on version 2.4.6) for about 6 months now, monitoring Linux and Windows servers, and also access points. Recently we bought 2 Cisco switches, the SG300-52 model. We installed one of them and I went to create a host in Zabbix, using two templates from this page, "envmon" and "interfaces". And as you can see, everything is OK.
Then I went to create the second host, but it simply won't display any of the interfaces information. Both switches are running the same configuration (snmp and interface related) and on the same sw and hw version (I can provide the config files if wanted), I've tried cloning the first host, creating from zero etc.
I'm not sure if the problem is withing Zabbix or with one of the switches. If you need any log files I can provide too.
Thanks in advance.
Regards,
W.
Thanks in advance.
Regards,
W.
