How can I work Oracle monitoring with Zabbix Agent 2?
  • rrruhena
    • Jul 2021
    Hello Guys! First post here!
    I am a old zabbix user (since 3.2) and recently, I make a new installation of 5.4 version.
    I want to use the Oracle plugin on zabbix-agent2, but I cant understand how it works or what I am doing wrong.
    I did the follow steps:
    1- I did install zabbix-agent2 on oracle server
    2 - I did create user with privileged content, like specified on Zabbix agent 2 template operation [Zabbix Documentation 5.4]
    3 - I had enable template linux and template Oracle by Zabbix Agent 2
    4 - I had configure template oracle 2 on Macros with oracle connstring, oracle.password and oracle.user
    After doing all of the steps, I received Oracle: Connection to database is unavailable message.
    Reading log files on oracle server, the follow message appears:
    021/07/12 14:25:39.377644 [Oracle] Connection failed: ORA-00000: DPI-1047: Cannot locate a 64-bit Oracle Client library: "libclntsh.so: cannot open shared object file: No such file or directory". See https://oracle.github.io/odpi/doc/in...ion.html#linux for help.
    But the library exists...
    Anyone can help me?
  • rrruhena
    • Jul 2021
    Any idea? I can't find more information about this... is there need enable anything on zabbix-agent2?
    • rrruhena
      • Jul 2021
      Where I have to install Oracle instant client? On zabbix Server or on my DB host?
      • Hernandes Martins
        • Apr 2011
        • 901
        Zabbix server or Zabbix Proxy
        __
        Att.
        Skype: hernandss
        Telegram: @MrHernandes
        Español
        Português
        • rrruhena
          • Jul 2021
          Ola Hernandes! Obrigado pela ajuda!
          Zabbix Server
          • lhmiranda
            • Sep 2021
            I'm having the same problem, and I tried installing the Oracle Instant Client on the Zabbix Server and I still get the same error.
            Are you sure it has to be installed on the server? I ask because I get this error on the zabbix agent2 side (installed on the Oracle DB machine), not on the zabbix server.
            I'm afraid of installing the client on the Oracle machine... I know very little about Oracle so I don't want to risk screwing something on our production database.
            Is it safe to install the Instant Client on the Oracle machine?
            • adoang
              • Sep 2021
              I am using oracle for zabbix agent 2 template. only asm is facing error. I use zabbix server 5.0.15 and zabbix agent 2 5.2.7
              please advise.
              Cannot create item: item with the same key "oracle.asm_free_size["{#DG_NAME}"]" already exists.
              • splitek
                • Dec 2018
                • 101
                please advise.
                This is bug in template. Zabbix agent return
                {#DGNAME}
                not
                {#DG_NAME}
                Just edit template and replace every occurrence of
                {#DG_NAME}
                to
                {#DGNAME}
                • adoang
                  adoang commented
                  thanks this is correct. but the asm is not loaded. Now the other issue is coming. please advise.
                  Preprocessing failed for: [{"ASM_ARC":{"total_bytes":214744170496,"free_bytes ":209136386048,"used_pct":2.61}},{"ASM_ARC...
                  1. Failed: cannot extract value from json by path "$..['ASM_ARC'].size_byte.first()": no data matches the specified path
              • splitek
                • Dec 2018
                • 101
                Please check items located in this template in discovery rule named "ASM disk groups discovery". There are items that have preprocessing and preprocessing is using this bad "#DG_NAME". I've also replaced this "#DG_NAME" to "#DGNAME" in preprocessing.
                Another error I found in JSONPATH:
                original JSONPATH:
                $..['{#DG_NAME}'].free_size_byte.first()
                new JSONPATH:
                $..['{#DGNAME}'].free_bytes.first()
                Replaced:
                "free_size_byte" to "free_bytes"
                "used_percent" to "used_pct"
                "size_byte" to "total_bytes"
                • adoang
                  adoang commented
                  This is working perfectly. thank you
                  is this templete will work with 11G or 12.1 version ?
              • splitek
                • Dec 2018
                • 101
                No.
                Developers tested this on: Oracle Database, version 12c2, 18c, 19c
                From Oracle 12 there were big changes... pluggable DB (CDB, non-CDB, PDB), multitenant etc. But most important is that from v12 Oracle supports JSON and Zabbix agent 2 Oracle Plugin is using this JSON to get statistics from DB.
                If you have older Oracle DB version then you need to use some other templates.
                • adoang
                  adoang commented
                  Hi Splitek,
                  Thanks for your help. for 11G and 12.1 version , I use ODBC templete.
                  can you please let me know how to add the Operational data % with bytes values ?
                  Problem: Oracle TBS 'MY_TBS': Tablespace usage is too high (over 85% for 5m).
                  Problem started at 14:01:29 on 2021.11.23
                  Host: myoracledbhost-sql
                  Severity: Warning
                  Operational data: 87.43 % +++ (100 MB) +++
                  Original problem ID: 1901826
              • splitek
                • Dec 2018
                • 101
                I don't know if I can help with that, but in general... in "operational data" in trigger we must use macros. Macro {ITEM.LASTVALUE} as is written here https://www.zabbix.com/documentation...ed_by_location is "The latest value of the Nth item in the trigger expression that caused a notification." So, if trigger is like this:
                {somehost:oracle.tbs_used_file_pct["SYSAUX"].min(5m)}>{$ORACLE.TBS.USED.PCT.MAX.HIGH}
                then our macro will resolve to value inside item with key:
                on host named "somehost"
                We can not add not used metrics in trigger to "operational data", but some people here use trick. Trick is to add to trigger another expression, expression that will always be true. And this expression must of course use our metric needed in "operational data".
                I never used that trick, but I think our trigger can look like that:
                ({somehost:oracle.tbs_used_bytes["SYSAUX"].last()}>-1
                AND
                {somehost:oracle.tbs_used_file_pct["SYSAUX"].min(5m)})>{$ORACLE.TBS.USED.PCT.MAX.HIGH}
                First line should always resolve to "true". In this line we have item with "Tablespace used, bytes". We can use this in "operatiopna data", put {ITEM.LASTVALUE1} ("1" at end is because our item is first item in trigger expression).
                • gspoli
                  • Dec 2021
                  Hello.
                  Could you get tablespaces info form CBDs and all PDBs?
                  In mine installation I was able to get or cdb or one pdb not all.
                  • splitek
                    • Dec 2018
                    • 101
                    I don't need tablespace info form PDBs (my DB have to many of them to give usefull info).
                    I think it will not work because LLD discovers Oracle tablespaces names (LLD macro is {#TABLESPACE}), and some tablespaces in different PDBs can have the same name (like SYSTEM). Items creaded by the TBS LLD rule have names like: "Oracle TBS '{#TABLESPACE}': Tablespace allocated, bytes", so Zabbix will try create two the same items and will fail. So I think this is the reason why PDBs tablespaces are not discovered.
                    You can... clone template, remove everything from it except LLD "Tablespace discovery", make another host only for specific PDB teblespaces. So you end up with separate host for every PDB.
                    Template can be extended to discover all tablespaces in all PDBs, but this approach needs that LLD rule get not lonely TBS name but "PDB name with tablespace name".
                    I mean, if agent use query like in this expamle: https://docs.oracle.com/en/database/...2643__CHDHDICB
                    and LLD macro {#TABLESPACE} do not get only "SYSTEM" but:
                    HRPDB-SYTSTEM
                    SALESPDB-SYSTEM
                    then it will work.
                    But it is up to dev to add this query to agent (or you can try implement this by custom query).
                    • gspoli
                      • Dec 2021
                      Thank you very much for you answer splitek
                      • adoang
                        • Sep 2021
                        #15
                        Hi
                        I put an plugin in zabbix agent 2 conf
                        Plugins.Oracle.Sessions.OraOp.Uri=tcp://127.0.0.1:1521
                        Plugins.Oracle.Sessions.OraOp.User=zabbix
                        Plugins.Oracle.Sessions.OraOp.Password=<password>
                        Plugins.Oracle.Sessions.OraOp.Service=opdb
                        zabbix_get -s 127.0.0.1 -k oracle.ping[OraOp]
                        ZBX_NOTSUPPORTED: Unknown metric oracle.ping
                        zabbix_get -s 127.0.0.1 -k oracle.ping[opdb]
                        and how do i put in item on frontend ?
                        because when I put oracle.ping[OraOp]
