Filtering in Problems menu
  • d31m0s
    • Jan 2019
    • 11
    Dear All,
    Do you know if it is possible to select which problems you want to hide in the Problems menu?
    If you want to see only problems related to zabbix agent, you just write "zabbix agent" they it will show only these problems.
    But if you want to show all problems except zabbix agent, how to do it?
    Thanks.
    Best Regards.
