Understanding HP Aruba SNMP Trap
  • Daniel4711
    • Jul 2014
    • 127
    Hello all,
    I have problems with SNMP traps from HP switches.
    Although I put all MIB files from HP in the /usr/share/snmp/mibs folder, in some cases I only get the numeric OID representation and not the name for an SNMP trap.
    Does anyone have any ideas here?
    14:35:25 2021/07/20 ZBXTRAP 172.19.16.2
    PDU INFO:
    receivedfrom UDP: [172.19.16.2]:161->[172.19.3.186]:162
    version 0
    notificationtype TRAP
    messageid 0
    transactionid 6666
    community zabbixtrap
    errorindex 0
    errorstatus 0
    requestid 0
    VARBINDS:
    DISMAN-EVENT-MIB::sysUpTimeInstance type=67 value=Timeticks: (1554452032) 179 days, 21:55:20.32
    SNMPv2-MIB::snmpTrapOID.0 type=6 value=OID: SNMPv2-SMI::enterprises.11.2.14.11.5.1.19.0.1
    SNMPv2-SMI::enterprises.11.2.14.11.5.1.19.1.8.0 type=2 value=INTEGER: 1
    SNMPv2-SMI::enterprises.11.2.14.11.5.1.19.1.6.0 type=2 value=INTEGER: 5
    SNMPv2-SMI::enterprises.11.2.14.11.5.1.19.1.26.0 type=2 value=INTEGER: 2
    SNMPv2-SMI::enterprises.11.2.14.11.5.1.19.12.2.1.9.1 type=66 value=Gauge32: 0
    SNMPv2-SMI::enterprises.11.2.14.11.5.1.19.1.27.0 type=2 value=INTEGER: 1
    SNMPv2-SMI::enterprises.11.2.14.11.5.1.19.1.28.0 type=4 value=Hex-STRING: AC 13 18 7C
    SNMP-COMMUNITY-MIB::snmpTrapAddress.0 type=64 value=IpAddress: 172.19.16.2
    SNMP-COMMUNITY-MIB::snmpTrapCommunity.0 type=4 value=STRING: "zabbixtrap"
    SNMPv2-MIB::snmpTrapEnterprise.0 type=6 value=OID: SNMPv2-SMI::enterprises.11.2.14.11.5.1.19
    My Configuration:
    Debian 10 with Zabbix 5.4
    /etc/snmp/snmp.conf
    # As the snmp packages come without MIB files due to license reasons, loading
    # of MIBs is disabled by default. If you added the MIBs you can reenable
    # loading them by commenting out the following line.
    # mibs +ALL
    All Originals HP Files (205 Files) are in the following Folder:
    net-snmp-config --default-mibdirs
    root@Zabbix:/usr/share/snmp/mibs# net-snmp-config --default-mibdirs
    /root/.snmp/mibs:/usr/share/snmp/mibs:/usr/share/snmp/mibs/iana:/usr/share/snmp/mibs/ietf:/usr/share/mibs/site:/usr/share/snmp/mibs:/usr/share/mibs/iana:/usr/share/mibs/ietf:/usr/share/mibs/netsnmp
    Thanks in advance!
    If someone still has a hint for me where I can find an overview of the possible traps... I would be very happy!
    I have all the files, but which traps there are or which are interesting for me, I have not found out yet.
    So far I can only use snmptrap.fallback....
    Best regards
    Daniel
