Zabbix 5.4.2 Oracle DB creation Scripts gives ORA-01722: invalid number
  • beremour
    • Jul 2021
    I've built zabbix from git tag 5.4.2. Oracle Database created with CHARACTER SET AL32UTF8 and NATIONAL CHARACTER SET UTF8.
    When I try to create Schema with database/oracle/schema.sql I am getting "invalid number" on table "services". Screen attached. What can I do with it ?
Name:	Screenshot 2021-07-21 at 00.43.36.png
  • Glencoe
    Zabbix developer
    • Oct 2019
    • 153
    What does this query say?
    select * from NLS_DATABASE_PARAMETERS
    • beremour
      • Jul 2021
      Thank you very much for reply! I found problem solution last night. It was NLS_LANG env variable on client side.
      I had:
      NLS_LANG=AMERICAN_RUSSIA.UTF8
      I switched to:
      NLS_LANG=AMERICAN_AMERICA.UTF8
      and BINARY_DOUBLEs began to work. But I think it's better to specify 9.99d instead on '9.99' for BINARY_DOUBLEs.
      Can you please look at another Oracle-scripts error at https://www.zabbix.com/forum/zabbix-...racle-database
      ? There are 2 of us with
      ORA-22835: Buffer too small for CLOB to CHAR or BLOB to RAW conversion
      Thank you.
