What does vfs.dev.util mean?
  • lpossamai
    • Jun 2018
    • 119
    Hello everyone!
    I'm troubleshooting a performance issue on my PostgreSQL stack that is running on EC2 instances in AWS.
    The instances have EBS GP2 volumes with 2048GB and a total of 6144 IOPS.
    You can see below that Zabbix reports the /pgsql volume to reach 100% of utilization. And the timing of those are exactly when I have the performance issues. However, looking at the AWS dashboard, I see that the disks are not reaching their limit.
Name:	Screen Shot 2021-07-21 at 11.09.30 AM.png
    So, I would like to know what does vfs.dev.util[] mean? Which Linux command does vfs.dev.util[] represent? I wanna know if that graph is valid and is showing real and valid data.
    Thanks in advance!
  • Markku
    • Sep 2018
    • 1784
    Hi, maybe the data is from /sys/block/DEVICENAME/stat? Based on https://git.zabbix.com/projects/ZBX/...s/linux_active
    Markku
