Zabbix 5.4 with Ubuntu 21.04 and MariaDB
  • nfoliveira
    • Jul 2021
    Hi Everyone
    I'm trying to install the Zabbix 5.4 over Ubuntu Server 21.04.
    Basically I'm facing many issues as libsnmp and others. However I'm trying now compile the build directly.
    Following the Zabbix Tutorial, (step 4)
    ./configure --enable-server --enable-agent --with-mysql=/usr/bin/mariadb --enable-ipv6 --with-net-snmp --with-libcurl --with-libxml2
    is showing this error
    checking for TLS support in MySQL library... no
    checking for TLS support in MariaDB library... no
    checking for MariaDB init options function... no
    checking for MySQL init options function... no
    no
    configure: error: Could not find the options function for mysql init
    Without parameter as below
    ./configure --enable-server --enable-agent --with-mysql --enable-ipv6 --with-net-snmp --with-libcurl --with-libxml2
    I have these message
    checking for mysql_config... no
    checking for mariadb_config... no
    configure: error: MySQL library not found
    Anyone had the same issue? or know what setup is necessary to fill?
    Thank so much
    Best Regards
  • secooonder
    • Jul 2021
    Hi
    I have the same problem.
    There seems to be no released version for 21.04 ?
    • Atsushi
      • Aug 2013
      • 2028
      Did you install a development package such as libmariadb-dev?
